Python SDK with JWT Auth to get EventLogs
I am trying to integrate Box admin logs with our SIEM solution for a client. I am trying to pull the event (admin) logs using box-python-sdk. I have tried two different methods as follows:
def get_sdk(): sdk = JWTAuth(client_id="", client_secret="", enterprise_id="", jwt_key_id="", rsa_private_key_file_sys_path="rsa_private_key.ppk", rsa_private_key_passphrase=b"", ) return sdk def method_1_get_token(): sdk = get_sdk() sdk = sdk._auth_with_jwt("", 'user') client = Client(sdk) events = client.events().get_events() print(dir(events)) print(events) def method_2_get_token(): sdk = get_sdk() client = Client(sdk) user = client.user(user_id="").get() client = client.as_user(user) events = client.events().get_events() print(dir(events)) print(events)
Both are returning different error messages.
method_1_get_token returns the exception:
Message: b'{"error":"invalid_request","error_description":"Cannot obtain token based on the enterprise configuration for your app"}' Status: 400 URL: https://api.box.com/oauth2/token Method: POST
method_2_get_token return the exception:
Message: Access denied - insufficient permission Status: 403 Code: access_denied_insufficient_permissions Request id: u9o2chfu9ii7lxe4 Headers: {'BOX-REQUEST-ID': '0am8fu2al2d6rrvs2gfjfhdaipe', 'Content-Encoding': 'gzip', 'Strict-Transport-Security': 'max-age=31536000', 'Cache-Control': 'no-cache, no-store', 'Date': 'Tue, 14 Aug 2018 12:40:57 GMT', 'Age': '0', 'Content-Type': 'application/json', 'Transfer-Encoding': 'chunked', 'Vary': 'Accept-Encoding', 'Connection': 'keep-alive'} URL: https://api.box.com/2.0/events Method: GET Context info: None
The client has enabled the app scope 'Manage enterprise properties' and the App access is set to 'Enterprise'
Any help will be greater appreciated.
Hello,
Thanks so much for using our platform and development forum!
For method 2 I'm seeing the following in our backend logs: "Missing+permissions+user_api_act_as_user". Have you enabled the as-user header in the developer console? After you enabled this did you re-authorize your application in the admin console?
If so, it would be best if you could open a ticket with all this information and your API key so we can help you further investigate!
Best,
Kourtney
Comments
1 comment
