Python 3 boxsdk
Highlighted
Occasional Contributor
Python 3 boxsdk
I see others seem to be using python3, but when I install boxsdk using pip, I can only run the little program snippet using python2:
i@raspberrypi:~ $ python3 boxInit.py
Traceback (most recent call last):
File "boxInit.py", line 1, in <module>
from boxsdk import OAuth2, Client
ModuleNotFoundError: No module named 'boxsdk'
In the past when I've used pip it was pip for python2, and pip3 for python3, but pip3 can't find boxsdk.  So...how do I install boxsdk so that it can be seen by python3?
I must be missing something simple since others are using python3.  What is it?
            Tom
Tags (1)
3 REPLIES 3
Highlighted
Box Employee
Re: Python 3 boxsdk
Hi @TPark_RL,
The Python SDK will support both Python 2 and 3 out of the box. It could be that the program you're trying to run was written with Python 2.x syntax, but if you write your own Python 3.x scripts with the SDK it'll work.
- Jon
Highlighted
Re: Python 3 boxsdk
Jon -
    Thanks for the reply.  You're probably right, but the script croaks on the first line:
This occurs when I execute it using: "python3 boxInit.py"
If instead I use "python boxInit.py" it doesn't croak, and the user ID gets printed.
boxInit.py is from your documentation:
auth = OAuth2(
client_id='<my client id>',
client_secret='<my client-secret>',
access_token='<my access token>,
client = Client(auth)
user = client.user().get()
print('The current user ID is {0}'.format(user.id))
Seems pretty simple.  Any ideas?
           Tom
Highlighted
First-time Contributor
Re: Python 3 boxsdk
Hi Team,
I'm seeing the same issue on my local. FYI I have python 3 installed o. my local but for some reason I get "
ModuleNotFoundError: No module named 'boxsdk'" this eeror. Any help is appreciated.
Ashish
