Not able to generate Access Token using Java Code: JWT without SDKs
New post
Comments
1 comment
  • jcleblanc
    Hi ,
    What version of JRE are you currently using? If it's < 1.8 can you update to at least 1.8 (which supports TLS 1.2) and try again please?
    For TLS connections, Box blocks TLS 1.0 communication, will be blocking TLS 1.1 after March 31st 2020. The standard version to use is TLS 1.2 for all API communication. TLS 1.3 is also being looked at for integration support, but I don't believe it's currently supported. The reason I say this is because you'll want to force TLS 1.2 otherwise you'll receive a connection error.
    - Jon
    0
    Comment actions Permalink
