Node red box integration fails to create credentials
I have created a Box Application to be used for API integrations. I am using Node Red Box node which is unable to leverage the api id and secret. It fails to store auhtenication credentials. It appears to be the URI which requires (htts) and the node red integration hard codes (http) as the call back uri
Comments
0 comments
