Need to set the expiration date on folder using box java sdk
Answered
New post
Comments
1 comment
  • Jason
    Hey ,
    Thanks for reaching out! "Folder expiration" isn't a feature offered by the Box API, unfortunately. You can set collaborations to expire via an enterprise-wide setting (for enterprises with Governance only), or you could potentially set up a workflow within your app to remove a collaboration after some time.
    In general, you can see the full API endpoints available from Box at https://developer.box.com/reference - most if not all calls have sample code snippets.
    Hope that helps!
    Thanks,
    Jason
    0
    Comment actions Permalink
