Move or Deleting file with BOX CLI.
SOLVED
Go to solution
Highlighted
New Contributor
Is there a way to move or delete a file with the command line tools? I have read this page: https://developer.box.com/docs/commands-and-actions
Is there a more comprehensive page or are those all the commands available? I would even be ok with being able to overwrite.
2 REPLIES 2
Highlighted
Box Employee
Re: Move or Deleting file with BOX CLI.
Hey @EricaC,
Great Question! There definitely is. What you'll want to do is run something like `box files --help` to see all of the available arguments and options. In general, the best thing to do is to start just adding --help to whatever command you're looking at, and "follow the path" of commands and arguments until you see what you're looking for.
Hope that helps!
Thanks,
Jason
Highlighted
Occasional Contributor
I want to do something similar - add new collaborators/co-owner (a service account who will own archived files) but then remove the original owner.
As far as I can see there is no option to remove collaborators, only add, is that correct? If so we can't actually completely transfer files and folders using the CLI.
Hopefully I have missed someting in the CLI documentation!
