Modifying tags with javascript/jquery
SOLVED
Go to solution
Highlighted
Occasional Contributor
All of the tutorials for BOX content API user cUrl examples and when I contacted tech support, they sent me here.
I am trying to udpate 21000 files with tags from a database. I have everything working except for the last step - updating the files on box with the tags.
Can some one please tell me how to use javascript/jquery/ajax to perform this cURL put?
curl https://api.box.com/2.0/files/FILE_ID \
-H "Authorization: Bearer ACCESS_TOKEN" \
-d '{"tags":"[tree,dog,grass]"}' \
-X PUT
I have searched this community and found nothing. I have searched the web and found how to get a folder but cannot figure out how to modify metadata of a file. My current ajax call DOES return the file object that I'm trying to modify. I tried GET and PUT ajax types.
Thanks
1 REPLY 1
Highlighted
Re: Modifying tags with javascript/jquery
Figured it out:
writeTags = function(tags, callback)
     var authHeader = "Bearer " + access_token;
     var tagsArray = tags.split(',');
     var url = "https://api.box.com/2.0/files/" + currentFile.id;
     $.ajax({
          url: url,
          type: 'PUT',
          data: JSON.stringify({tags:tagsArray}),
          beforeSend: function(xhr) {
               xhr.setRequestHeader("Authorization", authHeader);
         }, success: function(data){
                callback(data);
         error: function(xhr, textStatus, error){
              console.log(xhr, textStatus, error);}
