Maximum offset?
Answered
New post
Comments
2 comments
  • mwiller
     Due to backend limitations, it is not possible to use offset-based paging for collections of over 300,000 items.  You'll need to use marker-based paging as detailed in the Get Folder Items API Documentation by setting the `usemarker` query parameter to true, and using the returned marker to access the next page.
    0
    Comment actions Permalink
  • aw685
    Thanks for the reply! I will switch over to a marker-based implementation instead.
    0
