Json Web Token
I am using jwt based authentication provided by https://github.com/box/box-java-sdk/tree/master/src/example/java/com/box/sdk/example from git hub, I integrate this stand alone application to web application and I deployed successfully but when I am trying to access the one of box file it throwghing the error stating that bad major version
Then I find that box_java_sdk2.1.1.jar is build using the jdk 1.7 and my server runtime is jre 1.6
But, If there any support for JWT authentication using jdk 1.6
Can you please provide the any java-box-sdk jar which supports jdk 1.6
Comments
0 comments
