JWT Cannot read Property 'split' of undefined
Highlighted
New Contributor
Hi Everyone,
I'm trying to use the Node SDK  for JWT Authentication in a React App (and using Webpack). I'm running into the exact same issue as described here:
https://github.com/box/box-node-sdk/issues/288
Since it looks like the Node SDK isn't supported running in a browser via webpack, I tried to do the auth without the sdk:
https://developer.box.com/guides/authentication/jwt/without-sdk/
However, I'm running into the same issue.
Any thoughts on how to resolve?
3 REPLIES 3
Highlighted
Box Employee
Re: JWT Cannot read Property 'split' of undefined
Hi @andrewk26,
I would recommend taking a look at the community JavaScript SDK that's available, that might provide a solution for what you're trying to do.
Other than that, if you can supply the code for what you're trying to do and where you're getting the error then we can take a look to see what the issue might be.
Thanks,
Jon
Highlighted
New Contributor
Hi @jcleblanc
Here is my code. First, I have my async function since we are using await:
async function authServiceCredentials(config_json)  {
    const config = config_json;
    let key = {
        key: config.boxAppSettings.appAuth.privateKey,
        passphrase: config.boxAppSettings.appAuth.passphrase
    const crypto = require("crypto");
    const authenticationUrl = "https://api.box.com/oauth2/token";
    let claims = {
    iss: config.boxAppSettings.clientID,
    sub: config.enterpriseID,
    box_sub_type: "enterprise",
    aud: authenticationUrl,
    jti: crypto.randomBytes(64).toString("hex"),
    exp: Math.floor(Date.now() / 1000) + 45
    const jwt = require('jsonwebtoken')
    let keyId = config.boxAppSettings.appAuth.publicKeyID
    let headers = {
    'algorithm': 'RS512',
    'keyid': keyId,
    let assertion = jwt.sign(claims, key, headers)
    const axios = require('axios')
    const querystring = require('querystring');
    let accessToken = await axios.post(
    authenticationUrl,
    querystring.stringify({
        grant_type: 'urn:ietf:params:oauth:grant-type:jwt-bearer',
        assertion: assertion,
        client_id: config.boxAppSettings.clientID,
        client_secret: config.boxAppSettings.clientSecret
    ).then(response => {return response.data.access_token})
    return accessToken
From there, parse my JSON credentials and call the function:
const config = JSON.parse(this.props.serviceCredsJSONStr);
return authServiceCredentials(config).then(response =>{                                                     console.log(response)}).catch(err =>console.log(err))
The error I am getting is as follows. It is getting tripped up at jwt.sign
TypeError: Cannot read property 'split' of undefined
    at decrypt (index.js:100)
    at parseKeys (index.js:53)
    at sign (sign.js:10)
    at Sign.signMethod [as sign] (index.js:41)
    at Object.sign (index.js:152)
    at Object.jwsSign [as sign] (sign-stream.js:32)
    at Object.JWT.sign (index.js:137)
    at _callee$ (BoxFileExplorer.js:167)
    at tryCatch (runtime.js:62)
    at Generator.invoke [as _invoke] (runtime.js:296)
    at Generator.prototype.<computed> [as next] (runtime.js:114)
    at step (BoxAuthServices.js:2)
    at BoxAuthServices.js:2
    at new Promise (<anonymous>)
    at authServiceCredentials (BoxFileExplorer.js:131)
    at BoxFileExplorer.loadChildren (BoxFileExplorer.js:190)
    at loadChildren (index.js:64276)
    at TreeNode.onToggleClick (index.js:19859)
    at Object../node_modules/react-dom/lib/ReactErrorUtils.js.ReactErrorUtils.invokeGuardedCallback (ReactErrorUtils.js:70)
With the node sdk, the following is my code. I get the same error as above
var BoxSDK = require('box-node-sdk');
var sdk = BoxSDK.getPreconfiguredInstance(JSON.parse(this.props.serviceCredsJSONStr))
var client = sdk.getAppAuthClient('enterprise')
client.folders.getItems('0').then(response =>
           {console.log(response)}).catch(err =>{console.log(err)})
Any thoughts? Both of these options work outside of my react app in a normal Node environment on my desktop.
Highlighted
Box Employee
Hi @andrewk26,
From the code sample that you posted it looks like you're using the crypto package, which is the problem that the issue you referenced referred to. If the issue is accurate what you can try first is to replace the crypto requirement with one that supports running in a browser via Webpack.
Here's a list of alternative crypto libraries. Specifically it looks like this library was built to specifically solve this issue, so give that a shot as a crypto replacement.
- Jon
