Integration Pattern Advice (Using Castiron)
HI there
I have been struggling with Box.com for several weeks so think it is time I got some clarity.
My use case is, a 3rd party partner of mine share files (max 5 MB in size) with me via Box.com. I want to
- List files
- download each file
- process each file
- delete file
So the file/folder api works great. But my problem is when I try to establish bearer token.
I tried oauth with JWT but using my tooling, I cannot find a away to build JWT token. The signing of data is problem. It works no problem from SDK.
My tool, IBM Websphere CastIron has a BOX.com connector. But there are some many settings on connector I wonder is old.
- First question, am i using correct approach & is there alternative pattern to using OAUTH with JWT
- Second, does any one have experience with Castiron?
Thanks Ed
Comments
1 comment
