How to Create a Developer Token?
Hi, I'm just getting started with developing with the BOX APIs, and trying to create a Developer Token as outlined here:
https://developer.box.com/docs/authenticate-with-developer-token#section-creating-a-developer-token
However, the "Generate Developer Token" button isn't an option on my box application.
Thanks!
Hi ,
You'll be able to revoke primary access tokens as well as downscoped tokens and those developer tokens using the token revocation endpoint. For a developer token you'll also be able to revoke it from the same place where you generated it in the app (where mentioned). When you create the token the create developer token button will be changed to a revoke token button.
Thanks,
Jon
Comments
3 comments
