How does Box place the upload status flag?
New post
Comments
1 comment
  • jcleblanc
    Hi ,
    As far as I know the file object won't provide direct status information on the upload status of a file. The only info that I can see is item_status, but that will only show you if an item is active, trashed, or deleted.
    If you're uploading a file over 50mb and using chunked upload however, there is a way of doing this. Essentially chunked upload will break the upload into parts, and you'll upload each part in sequence. You can build a rudimentary status indicator by increasing the upload % each time a new part uploads successfully ((100% / # of total parts) * number of parts uploaded).
    - Jon
    0
    Comment actions Permalink
