Generate a token
Anybody here knows how can I generate a token to run a curl since POSTMAN in my computer for make a tests with the links from box?
Hi ,
The easiest way would probably to use a developer token, which can be generated through the application creation UI and will last for an hour. Documentation is available here on how to create one.
- Jon
Comments
1 comment
