File upload not working with PHP curl method (https://developer.box.com/v2.0/reference#upload-a-file
Answered
New post
Comments
5 comments
  • vijeeshciber
    Hello Everyone,
    I have find out the solution for this issue. Following is my working code with PHP CURL.
    $url = 'https://upload.box.com/api/2.0/files/content';
    $json = json_encode(array(
    'name' => $file->filename,
    'parent' => array('id' => $folder)
    $params = array(
    'attributes' => $json,
    'file'=>new CurlFile(drupal_realpath($file->uri),$file->filemime,$file->filename)
    $headers = array("Authorization: Bearer ".$res_data['access_token']);
    $ch = curl_init();
    curl_setopt($ch, CURLOPT_URL, $url);
    curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
    curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
    curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, FALSE);
    curl_setopt($ch, CURLOPT_POST, true);
    curl_setopt($ch, CURLOPT_POSTFIELDS, $params);
    $response = curl_exec($ch);
    $responseCode = curl_getinfo($ch, CURLINFO_HTTP_CODE);
    $errNo = curl_errno($ch);
    $errStr = curl_error($ch);
    curl_close($ch);
    0
    Comment actions Permalink
  • Dipak384
    Can please give me this error solution.
    0
  • bala33
    Hello ,are you got any solutions for this issue.
    0
  • elii
    Hi !
    Welcome to the Box Community and thank you for your first post!
    Did the solution provided by the original poster not work for you? If not, can you give us more details on the kinds of issues you're facing? This will help other community members understand how to help you best!
    Thank you again for posting, and hope to hear back from you soon!
    Emma
    Box Community Management Intern
    0
  • bala33
    Hi, Thanks,
    ya, it's working below I provide code.
    $pathoffile=$_FILES['boxfile']['tmp_name'];
    $filename=$_FILES['boxfile']['name'];
    $handle = fopen($pathoffile, "r");
    $data = fread($handle, filesize($pathoffile));
    $tokens = array();
    $tokens[] = "tokenkey";
    $serverKey ="Bearer tokenkey";
    $attributes = array('name' => $filename, 'parent' => array('id' => '0'));
    $params = array('attributes' => json_encode($attributes));
    $headers = array();
    $headers[] = 'Content-Type: multipart/form-data';
    $headers[] = 'Authorization: key='.$serverKey;
    $ch = curl_init();
    curl_setopt($ch, CURLINFO_HEADER_OUT, true);
    curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
    curl_setopt($ch, CURLOPT_POSTFIELDS, array(
    'file' => curl_file_create($pathoffile),
    curl_close($ch);
    0
