Fail to search folder info on my box app through Python BoxSDK(JWTAuth) token
Answered
New post
Comments
2 comments
  • mbehn-box
    Hi lingjshi,
    When you generate a developer token in the Dev Console, it generates a token for your personal box account that you created the application under. So, if you have this content in your personal account, it would surface in a search using the developer token for your personal account.
    When you generate a token using the Python SDK, it generate's a token for your application's Service Account  within the Box Enterprise - not your personal account. If you upload content to the Service Account through the API, it will be searchable using the token returned from the Python SDK.
    Hope this helps!
    0
    Comment actions Permalink
  • lingjshi
    Hi mbehn,
    Thank you for your advice.
    I followed Service Account  , added my service account as a collaborator, it is working well with token generated via Python BoxSDK.
    0
