Error Handling Python (ie. 409 error)
Answered
New post
Comments
1 comment
  • jcleblanc
    Hi ,
    Here's what you'll want to do:
    1. Listen for the 409 error with the item name in use description coming back whenever you're trying to upload a file (try / catch block)
    2. When that error occurs, you can do a few things. You can instead call the update file endpoint to push a new file version up, or you can change the file name (e.g. filename(2).txt) and try the upload again.
    I don't have the code in Python, but I do in Node and Java, if that helps provide some guidance:
    Node
    client.files.uploadFile('0', 'tempdoc.txt', stream).then((err, metadata) => {
      console.log("file uploaded");
    }).catch(function (err) {
      if (err.response && err.response.body && err.response.body.code === 'item_name_in_use') {
        console.log('duplicate file detected');
    Java
    String filePath = "/localdir/temp.txt";
    String fileName = "current.txt";
    String folderId = "0";
    // Select Box folder
    BoxFolder folder = new BoxFolder(client, folderId);
    try {
        // Upload file
        FileInputStream stream = new FileInputStream(filePath);
        folder.uploadFile(stream, fileName);
        stream.close();
    } catch (Exception e) {
        if (e.getMessage().contains("item_name_in_use")) {
            System.out.println("Duplicate file name detected");
    0
    Comment actions Permalink
