Enable manage webhook
Highlighted
Occasional Contributor
Hi,
I am trying to creating webhook in the box using node js. but i am geting below error.
" Unexpected API Response [400 Bad Request | 92k219gf4n2o84dh.0d7af43b9b17df6e137fa9a42eb6dc1e7] bad_request - Bad Request".
might be webhook is not enabled for our app. can you please suggest the solution.
3 REPLIES 3
Highlighted
Box Employee
Re: Enable manage webhook
Hi @ashishu,
Can you post the code snippet that is causing that error please? From the error it sounds like something might need to be adjusted in the call to create the webhook.
Thanks,
Jon
Highlighted
I have enabled the manage webhooks from developer console but still i got 403 error. please have at my code
exports.createwebhooks = function(req,res){
                // Initialize the SDK with your app credentials
                var sdk = new BoxSDK({
                    clientID: CLIENTID,
                    clientSecret: CLIENTSECRET
                    var requesttoken='x3nzT8cftNZOvAcH68SwRoYakkx56HMo9b1bcwqQxoDEbceChYtit436bsAyw7XK';
                    TokenManager.findOne({ type:'refreshtoken' }, function (errdata) {
                    // console.log('data====',data);
                        if(data == null){
                            console.log('in ifffffff====');
                            TokenManager.create({ refreshtoken:requesttoken,type:'refreshtoken' }, function (errsmall) {
                                if (errreturn handleError(err);
                                // saved!
                        }else{
                         requesttoken=data.refreshtoken;
                        //requesttoken='XioYQyBX6twb08Zefyz91KaxAKBk1gu0b3eNaWTvQxkwgYH0n8bgt7peLAs7Tcis';
                        //console.log('requesttoken==',requesttoken);
                        var options1 = {
                            url: 'https://api.box.com/oauth2/token',
                            method: 'POST',
                            headers: {
                                'Content-Type': 'application/x-www-form-urlencoded'
                            form: {
                                'client_id': CLIENTID,
                                'client_secret': 'm7cMQZiRfIDNoFOsiYKHNadouDTon13h',
                                'refresh_token': requesttoken,
                                'grant_type': 'refresh_token',
                        request(options1callback44);
                    function callback44(errorresponsebody) {
                        console.log('response==',response);
                        if (!error && response.statusCode == 200) {
                            var bodydata = JSON.parse(body);
                            console.log('bodydata==',bodydata);
                            TokenManager.findOneAndUpdate({type:'refreshtoken'}, {$set:{refreshtoken:bodydata.refresh_token}}, {new: true}, (errdoc=> {
                                if (err) {
                                    console.log("Something wrong when updating data!");
                                console.log('bodydata.access_token==',bodydata.access_token);
                            var client = sdk.getBasicClient(bodydata.access_token);
                                client.webhooks.create(
                                '111280604678',
                                client.itemTypes.FOLDER,
                                'https://vpma.associationstudios.com/api/webhookdata',
                                    client.webhooks.triggerTypes.FILE.UPLOADED,
                                    client.webhooks.triggerTypes.FILE.DOWNLOADED
                                .then(webhook => {
                                    console.log('webhook====',webhook);
                        else
                            //console.log('hreeeeeeeetop==',error,response);
Highlighted
is there any solution about webhook??
