Data retrieval through metadata
New post
Comments
2 comments
  • Murtza
    As you mentioned, it takes 10 minutes for our search index to reflect a newly uploaded file and its metadata.
    If you need to retrive a file's metadata within this 10 minute search index period, you can store the file id returned after uploading a file to Box. With the file id, you can use the Get Metadata On File endpoint to get the file's metadata.
    0
    Comment actions Permalink
  • jwu
    Hi,
    Thanks for replying.
    But what I actualy want is to retrive only specific files that satisfy the metadata value.
    Because I hav lot of files on Box Side.Retriving all files and checking there meta data hampers performance.
    I want to extract only files that satisfy metadata value I specify and that too my application works such that
    I upload a new file and page gets refreshed to extract files from box.
    And this refreshed page should have uploaded file as it is satisfying meta data specified value
    0
