DISABLE_TWO_FACTOR_AUTH ??
AnsweredHello,
I've seen the Box API provides an Event to detect enabling of the 2-factor authentication feature, called ENABLE_TWO_FACTOR_AUTH.
Is there a way to know when this feature is disabled?
Thanks in advance.
Great :). Thanks for that answer.
Maybe you want to update the event documentation at https://developer.box.com/v2.0/reference#standard-user-events
Comments
2 comments
