Custom Box integration with Salesforce
Hi,
I am in the process of evaluting building a custom integration with salesforce and wanted to know the feasibility of the below items:
1. The BOX element within SalesForce has a navigation bar at the top that allows moving through BOX folders. We would like that disabled / removed so that the files uploaded to the opportunity are in the correct folder. The user should be prevented from directory recursion.
2. If I delete the folder from within BOX, the Opportunity then defaults to the ALL FILES folder on BOX. This should revert back to the initial FOLDER ICON to create a folder in BOX for the opportunity.
3. In addition to this, I would also like to know whether we can insert another sub-folder between the \Opportunity and \Opportunity_Name. For example, I would like to insert the current YEAR as a folder to help prevent overrunning the folder with thousands of entries.
SalesForce\Opportunity\ {YEAR} \ Opportunity_Name
Appreciate any input.
Thanks!
Comments
0 comments
