Connection exception - Couldn't finish closing the connection to the Box API
Answered
New post
Comments
2 comments
  • vmali
    This issue happens when I have a break point in the Box SDK code while getting a response for a request. I was doing to debug something and after that I started to getting this error.
    0
    Comment actions Permalink
  • jcleblanc
    Hi ,
    Yes, you should be able to reuse that auth object containing the access token. It may be worth sending this info into an issue on the Java SDK. They should be able to look a bit deeper into the SDK to see if there's an underlying issue.
    - Jon
    0
