Collaborations retrieve
The API call:
https://api.box.com/2.0/files/{file-id}/collaborations
authorized by (admin user/application user with all permissions), don't return collaborations of any external user.
This call returns the only of internal collaborations.
However there is no problem to view those collaborations via
https://{enterprise-domain}.app.box.com/file/{file-id}/collaborators.
Is there any way to get external user/collaborations via API - without knowing the exact user-login or collaboration-id?
Is there any way to get a list of them?
Hi !
Thanks for coming to the Box Community to post your question! We'd be happy to take a look at this for you, but we'll need to get some data about the calls you're making and examples of the responses you're getting first. For this, it would be best if we could communicate through a support ticket, where we'll be able to get that data and troubleshoot with you. Please raise a support ticket for this issue from support.box.com, include the information you used to create this post, and if you have this information available, it would be great if we could get the API keys you're using, the response you're seeing from Box, and a timestamp from the most recent reproduction attempts; this will go a long way toward helping us to troubleshoot your issue faster.
Thanks for coming to the Box Community, and we'll be looking forward to discussing this with you further in a support ticket!
Cheers,
Braden
Comments
1 comment
