Can not generate refresh tokens
New post
Comments
3 comments
  • cbetta
     the links seems to be live again. Can you retry?
    0
    Comment actions Permalink
  • SouravGC
    - Thanks for the reply , but still I am facing the same issue . I am getting a warnign as I mentioned below
    "Warning! Only use this tool with test client credentials/test Box accounts"
    Followings are my Client id and refresh id
    client - id is *** removed by moderator ***
    client secret is - *** removed by moderator ***
    0
  • cbetta
     thank you. I don't think anyone at Box actually controls this tool sadly, we are working on a new solution but that won't be available for a while.
    Please don't share your client ID and secret in public! These are secrets you should not share in a forum like this. Please make sure to reset them.
    0
