C# How do I detect Box files are syncing without using API?
Highlighted
New Contributor
Can I get the synchronization status of files locally using C # without using API?
I got the file's attribute when the orange icon is AI. But after synchronization with the server, its attribute do not change.
3 REPLIES 3
Highlighted
Box Employee
Re: C# How do I detect Box files are syncing without using API?
Hi @anhminhdhtv , we don't have an API for Box Drive to determine if the sync has completed, no.
Developer Advocate @ Box
Highlighted
New Contributor
Yes, thanks for replying to my post!
I have no intention of using the API. I just want to check locally.
The problem I want to check here is whether the file is syncing or not
I tried to get "Attribute" and "Availability" but it didn't solve the problem
Highlighted
Box Employee
Like I said, Box Drive does not provide an application interface to get this information today. If you want to make sure a new file version is uploaded programmatically we recommend writing a script to upload the file instead.
