BoxAPIConnection exception
Highlighted
New Contributor
Hi,
I am new to the box api. I have gone through the java box sdk and trying out to get connection with box with java client. I am simply printing the root folder in the below code but it is throwing an error:
package com.box.api.test;
import java.io.FileReader;
import java.io.IOException;
import java.io.Reader;
import com.box.sdk.BoxAPIConnection;
import com.box.sdk.BoxConfig;
import com.box.sdk.BoxFolder;
public class BoxAPIConnectionTest {
public static void main(String[] args) throws IOException {
Reader reader = new FileReader("resources/config.json");
BoxConfig boxConfig = BoxConfig.readFrom(reader);
BoxAPIConnection api = new BoxAPIConnection(boxConfig);
BoxFolder root_Fol=BoxFolder.getRootFolder(api);
System.out.println(root_Fol.getInfo().getID());
Error:
Exception in thread "main" com.box.sdk.BoxAPIResponseException: The API returned an error code [401 | .08e718937be17e68094d8f7a2c2ee84c]
at com.box.sdk.BoxAPIResponse.<init>(BoxAPIResponse.java:92)
at com.box.sdk.BoxAPIRequest.trySend(BoxAPIRequest.java:577)
at com.box.sdk.BoxAPIRequest.send(BoxAPIRequest.java:354)
at com.box.sdk.BoxAPIRequest.send(BoxAPIRequest.java:329)
at com.box.sdk.BoxFolder.getInfo(BoxFolder.java:288)
at com.box.api.test.BoxAPIConnectionTest.main(BoxAPIConnectionTest.java:16)
could you please assist that what would be the issue in my code?
2 REPLIES 2
Highlighted
Box Employee
Re: BoxAPIConnection exception
Hi @Teja2630,
This may be due to a few things - let's check off a few of the most common:
  1. Within the scopes of your application can you try setting "read and write all folders" to on if not already set.
  2. Did you (or your enterprise admin) authorize the app to work in the enterprise? You'll also need to reauthorize whenever there are scope changes to the app. If a JWT app isn't authorized it'll prevent you from making API calls.
Hopefully one of those is the cause,
Jon
Highlighted
New Contributor
Hi @jcleblanc ,
Thanks for the response.
I have made the configuration changes to my application as below:
App Type: Enterprise Integration
Auth Method: OAuth2.0 JWT
Application Access: Enterprise
App Scopes: as below
application scopesapplication scopes
and also authorized this app twice but still couldn't. and my self is the admin and there were no other users created.
