Box emulator
Highlighted
First-time Contributor
Box emulator
Hi,
It's currently a bit tricky to develop integration tests for any code that interfaces with Box. It quickly leads to shared credentials to a test account or similar. It's bad in enterprise environments and worse in open source.
Do you plan to offer any support for an emulated Box environment? Such as Azurite for Azure or minio / s3ninja for S3?
That would be very welcome.
1 REPLY 1
Highlighted
Trusted Contributor
Re: Box emulator
See https://support.box.com/hc/en-us/articles/360043697274-Managing-developer-sandboxes-for-Box-admins for Box’s developer sandboxes feature, which eliminates most of the risk as you develop code....maybe that’d do?
Hope that helps,
Ian Crew
UC Berkeley
