Box connector in streamsets
Hello,
I'm setting up a box connector in streamsets using HTTP client (so I can load files in a box folder to postgres)
I setup an app in box developer console and got the OAuth2 client id and secret.
I provided the client id and secret in streamsets and set the token url as https://app.box.com/api/oauth2/token
I set the resource ur in streamsets as https://api.box.com/2.0/folders//items
When I preview the streamsets connector I get the following error:
HTTP_01 - Error fetching resource. Status: 404 Reason: Not Found : {"type":"error","status":404,"code":"not_found","context_info":{"errors":[{"reason":"invalid_parameter","name":"folder","message":"Invalid value ''. 'folder' with value '' not found"}]},"help_url":"http:\/\/developers.box.com\/docs\/#errors","message":"Not Found","request_id":"qrj3yxfv0eup7sl1"}
When I use the OAuth authentication and header authorization with bearer token I'm able to see the folder contents.
Only when I change it tot OAuth2 with client id and secret the above error is shown.
Can someone please review and let me know what is wrong with the OAuth2 setup?
Comments
0 comments
