Box UI Elements conflicting order warning
Highlighted
Occasional Contributor
Hello my team is attempting to implement Content Explorer into our application. Everything functions correctly when run locally but when we go to build our app we are faced with a conflicting order warning. In order for our app to deploy it must compile without any warnings. The complete warning is as follows:
Compiled with warnings.
chunk 0 [mini-css-extract-plugin]
Conflicting order. Following module has been added:
* css ./node_modules/css-loader/dist/cjs.js??ref--6-oneOf-5-1!./node_modules/postcss-loader/src??postcss!./node_modules/resolve-url-loader??ref--6-oneOf-5-3!./node_modules/sass-loader
/dist/cjs.js??ref--6-oneOf-5-4!./node_modules/box-ui-elements/es/components/scroll-wrapper/ScrollWrapper.scss
despite it was not able to fulfill desired ordering with these modules:
/dist/cjs.js??ref--6-oneOf-5-4!./node_modules/box-ui-elements/es/components/flyout/Flyout.scss
- couldn't fulfill desired order of chunk group(s) activity-sidebar
- while fulfilling desired order of chunk group(s) metadata-sidebar
/dist/cjs.js??ref--6-oneOf-5-4!./node_modules/box-ui-elements/es/components/selector-dropdown/SelectorDropdown.scss
How would we go about resolving these?
1 REPLY 1
Highlighted
Re: Box UI Elements conflicting order warning
Checking to see if anyone has a solution as this is blocking our team from deploying our app.
