Box Sync interfering with JavaScript app running in a synced folder (uses Node.js)
New post
Comments
2 comments
  • jcleblanc
    Hi ,
    I'm not aware of anything in Box Sync that might cause this. Is your custom app using the Box APIs and Box Node SDK directly? If not I would recommend that as your first step, as the information that you need should work through our official tools.
    Another alternative is to check with the forum for Box Sync, they may have additional details.
    0
    Comment actions Permalink
  • ian_
    Thanks  ,
    We aren't interacting with Box in our app at all. I'll query the other forum as well.
    Cheers
    0
