Box-Git
Highlighted
Occasional Contributor
Box-Git
Hi,
I am trying to find out whether Box has Git repository app or not. If it have the Git app can you let me know where I can find that.
Thanks,
Naga.
6 REPLIES 6
Highlighted
New Contributor
Re: Box-Git
Were you able to resolve this? I have the same question: I would like to collaborate on a software development project with box.com hosting the repository, but am unclear on whether or not that is possible.
Highlighted
Box Employee
Re: Box-Git
@naga & @simonkahan Just wanted to clarify your question. Are you looking for a way to progamatically store a Git repo within a Box folder?
Highlighted
New Contributor
Re: Box-Git
I am looking to provide the same service as github in hosting a shared
repository that, for example, collaborators can push to without concerns
that one will overwrite the other's push operations if they both push
simultaneously.
Highlighted
New Contributor
Re: Box-Git
I have the same question.
I would simply like to be able to host a git repo on Box.  I can easily use my local filesystem; I can just as easily use a remote filesystem (e.g. "git clone ssh://myuser@/my/path/MyProject.git") or DropBox (which stores files locally).
Q:  Is there a way to use a Box folder as a Git repo?
Highlighted
New Contributor
Re: Box-Git
I have this issue.  Need a Box Git Repo.
Highlighted
First-time Contributor
Re: Box-Git
hi murtaza - did you get the ask/requirements - is athere a solution available ?
I want to use github app on desktop so i can point my repository to the box folder.
But then i need to host git server some where i guess
