Box CLI V2 doesn't use proxy?
New post
Comments
3 comments
  • VijayS1
    I have the same problem. I am running the following command in Box CLI.
    PS C:\Program Files (x86)\@boxcli> box tokens:get -user-id $user_number
    tunneling socket could not be established, statusCode=408
    The version I am using
    /cli/2.0.0 win32-x86 node-v10.10.0
    0
    Comment actions Permalink
  • ypenhas
    Hi guys,
    Did someone manage to use Box CLI v2 behing a company proxy  ?
    This is not supported in v2 while it was in previous versions, and it seems there is no official workaround.
    I try to find a workaround using something like SOCKSCAP64 (capturing the connection and redirecting through the proxy), but did not find a way to make it work yet.
    Did someone try to do it ?
    Any idea is welcome. Please share
    0
  • kshiraishi
    Hi
    Have you tried to set the https_proxy environment variable to your proxy on command prompt before running Box CLI commands?
    set https_proxy=http://proxy_server_name:8080
    set http_proxy=http://proxy_server_name:8080
    https://stackoverflow.com/questions/26992886/set-proxy-through-windows-command-line-including-login-parameters
    The above worked for me on Windows.
    0
