Authentication for large files using Content Uploader and chunk upload API?
Highlighted
First-time Contributor
I'm successfully completing some uploads using the Content Uploader UI, but occasionally get a 401 unauthorized error for large files (over 1gb).
Am I correct in assuming that this occurs when the file upload length outlasts the token life? If so, I don't see a refresh token endpoint or another way of extending the token expiration either before or during the upload.
Some details:
- Manually generating the JWT token server-side using PHP - no SDK is in use
- Chunk upload API is in use on content uploader, so there are separate calls to the upload endpoint
- Account settings allow up to 5gb per file
Can you point me in the right direction here or perhaps there is another issue causing the authentication error?
1 REPLY 1
Highlighted
Box Employee
Re: Authentication for large files using Content Uploader and chunk upload API?
Hi @RykerBennett, just to check, does the upload take longer than an hour?
Developer Advocate @ Box
