Access Token using Box api - Disabled by Box Admin
New post
Comments
1 comment
  • LoCortes
    Hello ,
    if that was working before and now that message appears means that your administrator has disabled the application on the APPs section of your BOX domain.
    When an application is created the Client ID has to be added to the BOX domain that will be using it (if it is private) or if published is enabled on the extensive list that appears on the APP management section.
    So, you have to request him/her to enable again for you.
    Regards,
    0
    Comment actions Permalink
