Access-Control-Allow-Origin
Highlighted
New Contributor
Hello Sir
Greetings of The Day
I wish to bring it your kind notice that Currently i am Integrating Salesforce to Box.com and I am facing a Issue regarding uploading a file .
Following Error I got:
"Access to XMLHttpRequest at 'https://upload.box.com/api/2.0/files/content?parent_id=0' from origin 'https://c.ap15.visual.force.com' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource."
Let me Know if You have any further queries on the same ,awaiting your response.
Thanks and Regards
Sanjay Kumar Prajapat
3 REPLIES 3
Highlighted
Box Employee
Re: Access-Control-Allow-Origin
@sanjayPrajapat please have a look at this page:
https://developer.box.com/guides/best-practices/cors/
You will need to enable CORS for the domain you're working on.
Developer Advocate @ Box
Highlighted
New Contributor
Sir
I have already did it,still i have got error
Highlighted
Box Employee
Ok great!
If you are using the standard Box for Salesforce managed package integration, then you may need to add the domain(s) to Salesforce’s Remote Site Settings:
https://help.salesforce.com/articleView?id=configuring_remoteproxy.htm
For Communities and Lightning components in general, you need to add the domain(s) to CSP Trusted Sites:
https://help.salesforce.com/articleView?id=csp_trusted_sites.htm
