APIs fail with TaskCanceledException
New post
Comments
1 comment
  • mwiller
     That sounds like an issue with how the .NET runtime you're using is handling network connections rather than a Box API issue, since you're not receiving an error response from Box but instead seeing the entire network request canceled.  Unfortunately, I'm not able to diagnose the root cause of the issue immediately, but I can at least tell you that it's almost certainly not due to your Box plan or anything like that!  If you're still having issues, please feel free to file an issue directly over at https://github.com/box/box-windows-sdk-v2 and the SDK team can help you troubleshoot
    0
    Comment actions Permalink
