Showing results for
Search instead for
Do you mean
Box for Workplace by Facebook
by Tuesday (137 Views)
The Box for Workplace by Facebook integration allows customers to use Box as their cloud content management solution while enjoying familiar social and collaboration solutions from Workplace. Users can easily share or access content stored in Box from within Workplace. We believe that organization should have the ability to choose where to store and manage their content.
Note: This integration is only available to Business-Level Box accounts or higher. Users must also have a Workplace account to make use of this integration.
Installing Box for Workplace by Facebook
In Box:
Simply add the integration to your Box account here.
In Workplace:
  1. While logged into Workplace as a System Administrator, navigate to the Company Dash-
    board. Select the Integrations tab on the left-hand side.
  2. Select the + symbol next to Box.
  3. A popup window will appear. Copy the API Key from that page. You will need to input that into Box’s Admin Console.
  4. Open Box in a new window, and then open the Admin Console.
  5. Open Enterprise Settings, and navigate to the Apps tab.
  6. Under Custom Applications tab click Authorize New App.
  7. Enter the API Key you copied from Workplace and select Next. Confirm the integration by selecting Authorize on the next screen.
  8. Navigate to the Account Info tab of Enterprise Settings. Note: You must be the primary administrator of your Box account to access this page.
  9.  Copy the Enterprise ID.
  10. Navigate back to Workplace and enter the Enterprise ID in the Install Box popup.
Using the Integration
In Box
To share a file directly to Workplace:
  • Right-click the file or click the ellipses (...) to open the More Options menu.
  • Under Integrations, click Share to Workplace by Facebook
In Workplace
The Box for Workplace by Facebook integration allows users within Workplace to:
  • Share files from Box in Workplace using the Box File Picker
  • Share files from Box in Workplace using Shared Links that are recognized and unfurl automatically
  • Preview content shared from Box in Workplace (Public/Company links only)
  • View previously shared files from Box in the "Files" tab of a Workplace group
Security/Compliance Considerations
Some things to keep in mind when using the integration:
  • Once the integration is installed, Workplace may access, maintain, store, and process files stored in Box.
  • Storage of any information created and maintained through Workplace, such as commenting (in Workplace) on content previewed from Box, will not be replicated to or stored in Box.
  • Functionality within Workplace must be evaluated for compliance with your applicable laws, regulations, and standards. For example, commenting and discussing files in Workplace is not part of Box's HIPAA-eligible services.
  • Features and functionality such as Box Zones, Box Governance, etc. will not apply to Workplace.
Need Help?
Please sign in to see your available support options.
Unable to sign in? Click here.
Users Online (371)
Contributors
