Uninstalling Box Drive
Follow the instructions below to uninstall Box Drive:
Windows:
  1. Uninstall the application in the Control Panel
If you'd like to remove all traces of the Box Drive application from your machine:
  1. Go to %LOCALAPPDATA%/Box and delete the subfolder called Box
  2. Go to %PROGRAMDATA%/Box and delete the subfolder called Box
  3. In Regedit:
    • Delete HKEY_CURRENT_USER/SOFTWARE/Box/Box
    • Delete HKEY_LOCAL_MACHINE/SOFTWARE/Box/Box
Mac:
  1. Quit the application
  2. Run the uninstaller script:
    • Launch Terminal.
    • Type the following and press Enter:
      sudo "/Library/Application Support/Box/uninstall_box_drive"
Version history
Revision #:
11 of 11
Last update:
‎01-02-2018 05:04 PM
Updated by:
Labels (6)
