Print Files From Box
With the update to the Box Web Application User Interface, the option to Print your file has moved. Follow the directions below to print your files:
  1. Locate the file you would like to print in the Box Web Application.
  2. Click the file to open it in Preview.
  3. In the top-left corner of the Preview screen, click the down arrow the right of the file name.
  4. In the drop-down menu, find the option to Print at the bottom to print the file.
Here is what the menu looks like:
Note: In order to print a file, you must have Viewer permissions or above.
Version history
Revision #:
2 of 2
Last update:
‎11-29-2017 09:30 AM
Updated by:
Labels (4)
Contributors
