You can easily store and access files from Box while working in Adobe Acrobat DC or Adobe Acrobat Reader DC on your desktop.
To enable the integration in Acrobat or Acrobat Reader, simply add your Box account from either the Home view or the custom Open or Save dialog box.
Home View:
adobe1
Custom Save dialog:
adobe2
Once you've added your Box account, it will appear as an entry in the left pane. Click to see your files and folders in the right pane.
box for adobe - 3
Note:
Search, sort, and filter commands are yet not available in the Home view for Box files. Also, Box files are not auto-uploaded using Mobile Link.
For more information, see this Adobe support article: Access Box files in Acrobat DC, Acrobat Reader DC
Version history
Revision #:
9 of 9
Last update:
‎07-28-2017 12:29 PM
Updated by:
Labels (3)
Contributors
