Showing results for
Search instead for
Do you mean
Register today!
Attend BoxWorks
Desktop, meet cloud.
View resources
Large Scale Deployments - Box Notes
by ‎03-27-2017 12:30 PM - edited ‎07-25-2017 01:31 PM (1,103 Views)
We provide this installer to help make Box easier to install on multiple computers.
Windows:
Download the MSI Installer here: Box Notes MSI
The MSI does the following:
  1. Places the installer at Program Files\Box Notes Machine Installer
  2. Creates a registry key that runs the installer with --checkInstall flag when a user logs in
  3. At time of login, it installs Box Notes silently. If it's already installed or the user has chosen to uninstall, the MSI exits. The MSI runs at login because the user account may not exist at imaging time.
Remember, if you remove the MSI, Box Notes won't automatically be uninstalled.
