This feature allows users to share a folder of content publicly as a website with a personalized, static link. Custom Links can be used to share the contents of a folder within your account to anyone accessing that link.
Note: Old Box Experience
This page refers to the old Box experience. In Box, hover over a single file or folder with your mouse. If the item looks like the following image, you are in the right place.
Files and folders should look like this when you hover over them.Files and folders should look like this when you hover over them.
If the item does not look like the image above, visit one of the links below instead:
Note: Personal Box users are limited to one custom link per account (although they can create additional custom links for content owned by a Business account or above). Customers with Business accounts and above can create unlimited custom links.
Creating a Custom Link
Locate a folder that you own (not a collaboration folder owned by another user) and click Share to the right of the folder name. You can also open the More Options menu (...), and under Sharing, click Share Link.
In the pop-up that appears, click the Gear icon to modify advanced settings. Under Custom Link, enter your desired custom text and click Save. The custom ending to the link should be between 3 and 30 characters and can use letters, numbers and hyphens.
Additionally, it is possible to password protect a Custom Link. For more on password protecting a Share Link, please see this article.
Using Shared Links
For more information on shared links follow the link to this help article:
Shared Links Overview And FAQs
