Showing results for
Search instead for
Do you mean
Register today!
Attend BoxWorks
Desktop, meet cloud.
View resources
Automatic Expiration for Collaborators
by on ‎12-14-2016 12:42 PM - edited on ‎07-24-2017 04:12 PM by (2,319 Views)
Depending on your organization's Enterprise Settings, collaborators may find that their access to a folder is set to expire after a certain period of time.
Note: Old Box Experience
This page refers to the old Box experience. In Box, hover over a single file or folder with your mouse. If the item looks like the following image, you are in the right place.
Files and folders should look like this when you hover over them.Files and folders should look like this when you hover over them.
If the item does not look like the image above, visit one of the links below instead:
If a collaborator is set to auto-expire, a clock icon will appear beside their name in the Collaborators sidebar. You can hover over the icon to view a collaborator's expiration date.
autoexpire - 1
Extending Collaborator Auto-Expiration
Folder owners have the ability to extend the auto-expiration date for a collaborator.
To extend a collaborator's auto-expiration date:
  • Click the collaborator's name in the Collaborators side bar to enter the Collaborator Management screen
  • Click the clock icon beside the collaborator whose auto-expiration date you'd like to extend.
  • Click Extend Access
autoexpire - 2
  • A confirmation message will be displayed with the new expiration date.
