Salesforce - Box - reporting?
New Contributor
Hi; anyone successfully reporting on the link between the two; for instance; how many Salesforce Accounts have Box folders created? This would be VERY useful for this change-over period.
Thanks.
Occasional Contributor
Re: Salesforce - Box - reporting?
Have you tried to report on the Salesforce FRUP object?
New Contributor
Hi, yes thanks. It's FRUP only though; I don't seem to be able to see Records with and without a related folder ID.
It'd be handy to be able to report on Records without a related FRUP folder.
First-time Contributor
I've been trying to figure this out as well.  Did you ever find a solution to pull this report?
