add/remove tags Box in iOS
SOLVED
Go to solution
New Contributor
The tag feature does not seem to be available in the iOS app. I cannot add / remove tags in iOS app.
Are tags supported in the mobile apps?
1 REPLY 1
Moderator
Re: add/remove tags Box in iOS
Hi @HungLD,
Welcome to the Box Community and thanks for your first post in the forum!
Apologies but using tags is currently not supported in mobile apps.
The Box Community team shares selected conversations on the community back to other Box teams from time to time, including product feedback. If you would like to submit your direct feedback,  we have recently launched a new way to submit product feature request directly to our product team: Box Pulse
Learn more about Box Pulse and how works, and please submit your suggestion and feedback to help us improve!
Thanks for your help and time in the Community!
Be sure to read our guidelines, Subscribe to content you like, and complete your profile on the community.
