Bookmaks showing in contents in Box Android App
New Contributor
Bookmarks shows up in contents instead of bookmarks tab in the android app for .pdfs in the default box pdf viewer.
Community Manager
Re: Bookmaks showing in contents in Box Android App
Hi @Lightinz,
 Welcome to the Box Community and thanks for your first post in the forum!
Could you clarify what you are seeing with a screenshot? This will probably require our Box Support to get involved if this is a mobile bug.
New Contributor
@Howard, here below i bookmarked a sample pdf in adobe reader and saved in box.Adobe Acrobat Pro DC ScreenShot.png
Now, after opening this file in the Android app, and clicking on Menu -> ContentsScreenshot_2018-02-06_214900.jpg
Screenshot_2018-02-06_214856.jpg(We see that the app is showing bookmars in contents tab, and the bookmark tab is empty - also navigation is not possible using contents Smiley Sad)
Some info:
Box Android App Version: 4.9.5
OS: Android Lolipop 5.1
