After April 30?
SOLVED
Go to solution
New Contributor
After April 30?
After April 30, 2019, Box will end support for Box Sync, Box Tools, Notes for Desktop and Box Drive on Mac OS X 10.12
Not sure if it's me or my cold, but I don't understand how this will affect me. . . Yes I do have a mac.
Lynn
4 REPLIES 4
Valued Contributor
Re: After April 30?
@SignaturedSign: I think that depends on whether you're still running macOS 10.12 on your Mac (you can see by choosing "About this Mac" from the Apple menu).
Hope that helps!
Ian Crew
UC Berkeley
New Contributor
Re: After April 30?
Thanks. I’m on 10.14.2, so I guess I don’t need to worry about it?
New Contributor
Re: After April 30?
I tried to change my avitar to a pict of a Shelby . . It won't let me change - says I used a bad word? Shelby.jpg?
Valued Contributor
Re: After April 30?
No, no need to worry if you're on 10.14...
Cheers,
Ian
