Creating a Box Note
To create a new Box Note from Box:
  • Navigate to the folder where you want to create the new Box Note.
  • You can add a new Box Note in one of two ways: (1) Click the Box Notes button or (2) Click New > Box Note.
  • Name your Box Note, then click Create. Your Box Note will be created in the folder that you are in. It will open in a new tab or window in your browser when you click Create.
  • Start typing in your new Box Note. All your changes are saved automatically.
To create a Box Note from the web interface or the desktop application:
  • Simply click the New button in the upper left.
  • You can choose to create a new Box Note from scratch, or you can use a Template to pre-populate the Box Note with predefined content.
Version history
Revision #:
5 of 5
Last update:
‎04-23-2018 02:04 PM
Updated by:
Users online (317)
