Installing Box Drive
New Contributor
When I try to install the .pkg file on macOS, Installer goes through the motions but when it gets down to "Installation" the bar zips up to the halfway mark and then stays there regardless of how long the installer has been running.
Tags (1)
Box Employee
Re: Installing Box Drive
Hi,
you can try to install it via command line and then share here where it fails.
 installer -pkg ./<package name> -target /
New Contributor
It says path not found.
