Box Sync Problem Notification - Name In Use
This rare issue may occur when Box Sync is resolving a file name conflict. If there is already a file in the sync destination location with the same name, you will see this error.
Environment
Resolution Steps
Check to see if there is already another file with the same name in the sync location. If so, rename the file and try to resync it.
Version history
Revision #:
1 of 1
Last update:
‎12-21-2017 11:21 AM
Updated by:
Labels (5)
Contributors
